The Radiator fan constantly running.
artorush
Oslo
Hello, I have a problem with my radiator fan on my 7m gte engine. The fan is constantly running when engine is on. I does shuts never off. Appreciate a lot if some one knew what cause this might be. Thanks.
WhtMa71
D0 W3RK
Apr 24, 2007
1,813
Macon, GA
That is not a problem.
It has a fan clutch and it should always be spinning when the engine is on. If it's not, you need to replace the fan clutch.
artorush
Oslo
It is the 91 model with the toyota logo. It is the largest radiator fan. I can seem to remember it should turn on and off to cool the radiator. Thanks.
gtsfirefighter
SM Expert on White trash
Sep 26, 2006
2,966
The largest radiator fan is the belt driven one so I assume you're talking about the big electric one in front of the radiator. It should not be running all the time.
mirage83
457
Georgia
Is your fan the stock mechanical fan, or has it been replaced with an electrical unit?
Supracentral
10
artorush - A stock supra can have up to 4 fans. They are:
  • Electric pusher fan in front of the radiator.
  • Mechanical main fan in back of the radiator in the center.
  • Electric pull fans (sometimes one, sometimes two) on the drivers side in back of the radiator.
Which one are you talking about?
artorush
Oslo
Thanks a lot for your help guys. Yep it's true I was talking about the belt driver fan... silly of me not knowing this. :3d_frown:
Koenigturbo
1,336
Oxnard CA
the belt driven fan:
The belt driven fan has a bi metal thermostatic check valve that when the tempurture gets hotter the bimetal expands and lets hydraulic fluid make a "connection" between the fan and the water pump shaft. maybe you have a stuck open check valve.
At least that's how Some American cars are, don't how Supra's do it.
artorush
Oslo
Hmmm.. sounds reasonable. Because I know I've seen the fan off when the engine was running. Dammit. Does any know where the check valve is placed on the 7m gte?
Koenigturbo
1,336
Oxnard CA
The check valve should be in the clutch itself, it's not some thing you replace by it self, you gotta replace the whole clutch.
Supracentral
10
Also, the clutch fan should never stop. It may run slow when it's cold, but it is not supposed to stop. If it does, either something is physically obstructing it, or the clutch has failed.
artorush
Oslo
Just read about it. It's true, it should always run. Thanks a lot for the information. :icon_razz
