Teaser pics of my new wheels
AGlobalThreat
Acceleration
Apr 4, 2005
991
Santa Clarita
jim1jz said:
I have those exact rims
My rears are in bad shape so I'm lookin for a set of 18's. Nice wheels
Sick jdm goodness!
91T breezen'
ROMNEY/RYAN 2012
Apr 4, 2005
1,149
NOYFB!
OneJoeZee said:
What's he need a spacer for? The offsets look fine...
I was thinking the same! If you are at the egde of the fenderwell with a +22 offset, a spacer will just push you outward, even more! Now, if you had a 40mm offset, then a 10mm spacer, would get you the desired look.
Stanzaspeed
2.5 Twin Turbo R
Calgary, AB
Sawbladz said:
You would run a +12 offset? How?
my front fenders are already rolled and trimmed paper thin, the rears will be done after new wheels are picked up.
im not going to run a huge tire on them either. i have another set of wheels for that...
+30mm offset on 9" wide is lame... the offset he has now is as high as id go personally in that width for anything other than a spare set of drag wheels.
but im insane :D
91T breezen'
ROMNEY/RYAN 2012
Apr 4, 2005
1,149
NOYFB!
It just depends on what look you're going for. If you want to dump the car pretty low, you have to think about offset alot more too!:icon_razz
Jeff Lange
Administrator
4,927
19
Sunnyvale, CA
jefflange.ca
Different people have different desired looks. Mr. Leany Shifter's desired look is total bollucks. Also, he likes men.
EDIT: True Story.
Stanzaspeed
2.5 Twin Turbo R
Calgary, AB
EDIT: True Story.
dont be mad just cause you still have sawblades jeff :D
Sawbladz
1,727
Oshawa, ON, CA
Did you ever deceide what size tires/what brand your going with? I'm really interested to see if you can fit a tire on there that you don't have to stretch. I think the max you will be able to run would be a 245 and those are slightly stretched on a 9" rim.
Imnotcreative72
100
New York
I Threw some 225/45/17's from an old set of wheels on my sterns. So I put my cusco's in and threw on the wheels. It's still missing a a lot of weight and sits high which sucks, but you get the idea.
