tb & tps for a ge, will it work for GTE
Dr Chill
4 hungry Supras
Nov 27, 2007
329
Mississippi
will a tb from a 7mge work on a 7mgte with all STOCK components
also the same for a tps , will a GE tps work on a GTE
Thanks
will a MOD please move my thread to the proper aera
Thanks
webbs7mgte
298
wisconsin
sorry im not a mod but im pretty sure the ge tb is different cus of the coolant lines that run to teh tb to prevent ice from forming in the tb and on the tb plate...but im not 100% sure only like 99% jk...but you can certintly try it are you running a 3000 pipe?
tbcmorris
SM Expert Thread Derailer
Mar 14, 2007
1,820
PRUVEN PERFORMANCE MILFORD CT
A 7mge tps will work on a 7mgte. Since the throttle bodies are postioned differently the blade inside the tps has to be clocked. I think 90 degrees. Other than that the plug is the same and the restistance is the same from both sensor.
I know this because my 7mgte has a 7mge tps.
I ohm checked it closed,at idle,at at wot and its the same.
Josh
