swap 2jz in mk3 at home
dashti
13
الكويت Kuwait
hi all
sorry for my bad english
i have supra mk3 ma70 7mge
i won't to swap in it 2jz-gte in home ...i have the engine with all part's of it
pleas what tools i need to swap it on it and any problem well happned to me ?
i have this tools
this to up the engine
what other thing i need
sorry for my bad english again :(
Aug 12, 2010
347
P.G. County, Maryland
You can pretty much take your entire car apart with just a 10 12 14 17 and 19mm wrench, but sockets would help you alot. You also need more parts. Not just the motor. You need to use the trans from the 7m, and you need the Jz bellhousing. You need a different driveshaft and crossmember, trans mount, and more. there are quite a few threads on here about it. Do you only have the motor? If so i would recommend you prepare further before you start, or you're going to have your car in pieces for a very long time.
