quick run down bc I'm on my phone and it sucks. bought the car with a bhg. its done and ready to go. stock except a rt dp. gets boost hard and fast but the car sputters or surges at high rpms... only in 3rd and higher gears
MDCmotorsports said:Careful when you use the word surge. Surge is actually a term used when talking about turbo charger performance.
If you're stating that the car jumps and stutters when under boost, it sounds like you may be hitting fuel cut.
Pull codes, and check back with us.
Check your boost hoses while you are at it.
Grimsta said:Ran, ok until the boost came in, the it hiccuped as long as it was there. Had AFM codes. Checked voltage at the AFM, replaced it, no more hiccup
