Supra Tems OEM struts
SUPRASTEVE
Supra Maniak
Jun 13, 2007
504
So Cal
I got some used oem struts from a friend he says they are in good condition which is good since mine are blown. I take them home and when i compressed them to check if they are good they just stood compressed. Is this normal? When i pulled them out they were very hard to pull out... also my friend says that all the tems are set on sport mood except for one which you can tell because it goes up and down easier than the others. I wanted to know if there was a way to tighten them or loosen them with out putting them on the car. I would like them to all be on normal when i put them on or all sport, it just makes it easier.
got_boosted
I need a turbo! >:(
Mar 3, 2006
608
Sacramento, CA
Is you're still using the TEMS actuators, they will adjust themselves the first time you turn on the key. As long as you installed the actuators correctly, it doesn't matter what setting the shock is on when you install it.
SUPRASTEVE
Supra Maniak
Jun 13, 2007
504
So Cal
suprarx7nut;1088552 said:
How hard was it to compress?
n=Not very hard, but I just found out they were blown, they have been sitting in a chevelle for 2 years go figure, oh well.
