Supra home
BamaSupra
14
Alabama
Finally went and picked up my 87 turbo today... time to start putting her together. 149000 miles should i rebuild bottom end since its already tore down to the block and can i get a few pics posted of almost stock engine bay so i can have a reference for vacuume hoses and such... i have double all the stuff to put a head back on the car inculding brand new ARP head Bolts no gasket tho and head needs to be baked and straighted if anyone has an idea of a cost on that? but anyway im rambling i will have pics posted later today i only payed 300 bucks for the car have a nice day ;)
jdub
Feb 10, 2006
10,730
Valley of the Sun
Concerning re-building the bottom end, you need to set your goals on what you want to do...an upgrade to the mid to high HP (400-500) numbers or leaning more modest close to stock HP (300-350). The turbo you choose will determine how stout a bottom end you need. Questions to ask yourself:
- How much $$$ do I want to spend ;) considering high HP is going to cost more $$$
- Which MHG to use? Cometic is good for most applications.
- Stock pistons or aftermarket? JE, Ross, Wisco...all good choices.
- Just a hone with stock pistons/oversize rings or bore it out for aftermarket.
- Stock rods? Usually good up to the 450 HP numbers....Eagle rods are good for most on the aftermarket side.
- Balance the rods & pistons?
- Turn/balance the crank or just micro polish the rod surfaces?
Regardless, you do want to have the crank checked out and use new bearings on the low side of Toyota spec for clearance. Replace crank/cam seals and timing belt with new. I feel a 3 angle valve job and replacing the valve seals is a must to do it right...measure and adjust the valve shims before you put the head on. The block and head will need to be decked to the RA spec for the MHG you chose.
BamaSupra
14
Alabama
here are some of the pics of the car and me loading it with my buddy
jdub
Feb 10, 2006
10,730
Valley of the Sun
Yeah...I'd have to pull that block just to paint it!
BTW...originally from B'ham...mom still lives there :naughty:
