Got a prob . Car idle's perfectly . Vac holds at 15 per boost gauge . No codes at all. Timing set at 12 . 99.5% sure all hoses and pipes are snug . Car bucks when I try to drive it . All gears cold or hot . I am kinda lost I checked everything that my manual listed on its trouble shooting guide in the chiltons.
Had a problem eariler with a little bhg goo on the oil cap but I think I took care of that . Recently swapped this motor in after a case of rod knock . ran fine for a few weeks went and did the knock sensor rewire and replaced the injector gaskets . Replaced the wire to the starter and ground . That is all the info I got any ideas . Thanks Matt
