So I got up and went to install my K&N FIPNK It's all going relatively smoothe, I have the intake pulled out (to make it a little easier) I get the point of removing the airbox from the mass air sensor...and find that there are four studs I need to remove.
The four studs located on the mass air sensor stand between me and getting this filter on. (The kit comes with bolts that actually fit their bracket as apposed to just tightening nuts onto the studs.)
I have no Drill, no Taps/Die set and no effing clue how to get these out other then a really violent and probably trip-to-the-hopsital resulting spree of forcing the studs out which will most likely end with me and shooting them with a shotgun.
All I have is a basic metric/Standard Ratchet set, some screw drivers, hammer etc....Gonna see if some one has a tap set I can borrow.
The directions say "If you can tighten to nuts on at once and then use the bottom to back out the stud they should come out"
Which translates mostly to "!@$!@$" I can understand it a little bit, but don't quite get how to loosen the bottom nut with the top one still intact? -shrug-
So any idea how to get these things off? I've searched all over google, goo-tube, and a little bit on SM
