Stock wing plugs?
Kylar27
Supra Lover
Oct 2, 2005
184
Connecticut
T34418L3ONE said:
i wanna remove my stock wing, where can i get plugs to seal the holes left by the wing?
you should be able to use a small rubber gromet. Hardware store or home depot, lowes, etc.
T34418L3ONE
Supra for brains.....
Jul 3, 2005
225
Pleasanton
I wanna avoid repainting the panel. Every body shop i went to said they just weld washers under the whole and fill it in with bondo. I dont wanna do that...
Ckanderson
2,644
The beach
why? It would look better then plastic plugs sticking out.
...that will get water trapped around them and rust, or just plain fall apart from the sun
do it right, you won't regret it...
fiyota
I ♥ Boost
May 3, 2006
1,063
Kelowna, BC
I'd say use the plugs as a temporary to make sure you like the wingless look before you go and have it filled and resprayed...
