i have an 89 supra and i noticed under the passenger seat was an amp. it says fujitsu ten limited um-173 and has a part number 86280-14240. well before i knew it was there i wanted to hook up the radio, not stock but came with car and it wasnt hooked up. in the dash behind the radio i saw two plugs that were plugged into each other and another connector by itself. i found a wiring diagram and unplugged the connectors and snipped the mail ends and hooked them up to my radio and it worked fine. then i found the amp and noticed it had the same plugs. so i went behind the radio and disconnected my connections and reatached the male connectors and plugged it in. so now i have all the speaker wires, ignition, positive and negative power, antenna, etc. split between two connectors which runs to the amp then another different connector as stated above back behind the radio. i cut the connector off and figured out that the grey wire is negative and the blue wire was positive. but i cant figure out which wire is ignition. any help would be awesome or a wiring diagram because i dont know which wire it is
thanks!!!!!
