Starting issue
the_ghost
23
Columbus, OHIO
My supra was running great until I went to start it up today...It would start, idles for 2-3 seconds if that, acts like it is not getting fuel...When I hit the gas pedal it seems to stall the engine more or makes no difference.
I have checked:
1.) Fuel pump is good? (Checked fuel line there is fuel and I hear the pump)
2.) There's RPM during brief start up and/or cranking (around 400-500rpm)
3.) Codes 12, 14, and 24
4.) Wiggled CPS wires
5.) Have not checked timing but did crack the timing cover and belt seems fine.
Ruled out code 12 because car had RPM signal. Thought it was ignitor due to code 14 switched to a used ignitor and same issue, still have above codes and now plus code 51.
There's fuel, spark (temporarily?), and should have good compression as it was running fine when I parked it. Again the car would start, idles low (2-3 seconds) and dies.
If you know please help me out.
Thanks!
