Stainless steel
For tubing:
http://lmgtfy.com/?q=aluminum+tubing
For hoses and fittings either go to driftmotion.com or summitracing.com and you can either order each hose from driftmotion which aarons prices are great. Or you could buy a bunch of bulk from summit. Summit might be a little cheaper for bulk stuff than from aaron. But his already made hoses are pretty good prices considering most fittings are like 8$ each.
Prolly custom made on everything.
With buying bulk and the right fitting you can make it look how ever you want. Ic piping zankoku in the vendor section sells a pre made ic piping kit ot you can ebay a cheap universal kit mock it up and take it to a welder.
Depending on which style hoses you want you might need to buy tools. The ones that driftmotion has a already mocked up and made so all you do is put them on.
Custom ones are some work for both.
