SS brake lines...why not?
lagged
1991 1JZ
new rochelle
http://www.nsxprime.com/FAQ/Performance/brakelines.htm
New information that I just received: Stainless steel lines have been known to fail when dirt gets between the outer braid and the Teflon lining... As the braid moves back and forth, the dirt abrades the Teflon and can make it rupture. If you look at stainless-steel lines on motorcycles, you'll see that many of them are encased in plastic tubing, apperently in an effort to eliminate this problem. If I don't sell my car before it's time to replace my lines, I'll probably put heat-shrink tubing around the new ones.
figgie
Twin Cities, Minnesot-ah
well you folks are aware that SS line regardless of manufacture (aeroquip, earls, russells, goodrich etc) have these lines a wear replacable items.. right???
