Spongey Brakes
Neodeuccio
Addicted to boost...
Sep 30, 2006
846
Schenectady NY
I just want to make sure I'm on the right track with this one.
My brakes feel awful. They work pretty well, but no matter how hard I push, the peddle never really gets hard, just spongey. I flushed the fluid maybe 5 months ago, and I replaced the entire from brake system minus the lines at the same time. So I'm certain it's the lines... Easily fixed by a set of stainless ones, right? Any other ideas?
mkiii222
Troy, MI
I'd go with the stainless lines and rebuild the calipers using the Toyota rebuild kit(~$20 per axle from the dealer).
The rebuild kit replaces all rubber parts on the caliper giving you a caliper that is just as good as new. I rebuilt mine when I replaced the pads/rotors and it made a huge difference. I still need to get new lines though.
Neodeuccio
Sep 30, 2006
846
Schenectady NY
I've got new calipers on the fronts, which I put on about 6 months ago. The rears are old. And yes, I bled the lines (to the best of my ability) when I flushed the system. I'll have to look into doing the rebuild... how much work is involved?
mkiii222
Troy, MI
If you have new(or reman) calipers up front I wouldn't bother rebuilding them.
As for the rears it's about an extra 5-10 minutes when doing a complete brake job. All you do is pull the old rubber bits off, slap some lube(supplied in the rebuild kit) on the shafts, and throw it back together.
I would consider it a PITA if rebuilding was all that was being done, but as stated it's only an extra 5-10 minutes if the car is already in the air and has the wheels off.
