Speedo cable
Angry7M
Formerly redmaro
Sep 6, 2007
733
AZ
Is the Speedometer cable driven??? Cause mine was leaking oil right above the dowpipe and i just pulled it and I came apart. Now my speedo wont work right or it wont move at all. Is it broken??? LOLz
Angry7M
Formerly redmaro
Sep 6, 2007
733
AZ
The thing is that I had the manual R154 swapped into my car(it use to be an auto). So would I need to buy the speedo cable for a 5 speed??? Or an auto??? Im confused!!!!
Anyone know how much they run for?
Angry7M
Formerly redmaro
Sep 6, 2007
733
AZ
OK I just rotated the long cable center cable with my hand and the speedo does move. So its probably just the short speedo cable, the one that hooks up to the transmission. Its leaking oil anyways so I might as well replace it. I just want to make sure that thats what I need. Thanks
anyone know how much the short speedo cable that hooks up to the trans costs? Thanks
tlo86
Ninja Editor 'Since 05'
Jul 24, 2005
3,914
Colorado
i used a auto cable on a manual trans they both work the lengths just seem a bit different
Boosted516
Supramano
Apr 13, 2008
475
Long Island, NY
my car also had a r154 swap but my cable was cut right near the transmission, so i just bought both peices....just go to the parts section and find someone parting out a 5 speed(im not sure if turbo or non turbo matters, maybe someone else knows?)
Angry7M
Formerly redmaro
Sep 6, 2007
733
AZ
Okay I just played around with the connector and the speedo seems to be working fine. The thing is that the short cable that is hooked up to the transmission is leaking what appears to be tranny gear oil from the center or the cable. So should I buy the short speedo cable to fix my oil leak??? Or is can the seal or something be replaced???
Anyone know what the short cable costs at the dealer??? Thanks guys
FIL
227
Thornlie
blog.highoctanephotos.com
more speedo cable questions....
by the sounds of it, the upper cable should rotate fairly freely when you try to twist the drive section from the bottom end?
mine takes a bit of effort to do (can't do it with fingers, but can with pliers)
i guess it's seized up.... anyone elses done this, and if so, did you need to replace the lower portion as well? (stripped gears / snapped drive on the short section?)
Thanks for your help guys, trying to get as much info as possible before I start ordering parts...
teedoff00
14 psi boost
Dec 5, 2007
297
Selah, WA
I just ordered the top piece from Jeff Watson at Champion and it cost me like 72 bucks. So they are pretty pricey but then again so is a speeding ticket!!:nono:
Good Luck
Kckazdude
1,239
Memphis, TN
^^ You think that is bad, try the little elbow on the auto tranmissions. Never would have thought that little peice would be so much.
Angry7M
Formerly redmaro
Sep 6, 2007
733
AZ
Well i got it fixe a few weeks ago, and i ended up replacing the short piece the one that hooks to the trans, overall it was pretty easy. I paid $36 dlls at the dealer for the short speedo cable that hooks to the trans.
supraguy@aol
Well-Known Member
Dec 30, 2005
4,281
71
Atlanta
Damn- I paid $16 at my dealership.
