speed sensor actuator
ma70mkiii
139
ohio
OK this may be a stupid question. IDK! The speed sensor that is by the brake master cylinder that has vacuum lines and a cable that connects to the bracket where the throttle cable goes. I didn't know if it had anything to do with the speedometer or anything important. I want to remove it because I am putting in a 1jz and I didn't quite know the function exactly. Please help me. Plz dont make fun of me:dunno:
tlo86
Ninja Editor 'Since 05'
Jul 24, 2005
3,914
Colorado
it is the cruise control and you can take it off if you want to. there is a boost sensor there as well for your boost gauge you might as well take that off too since the stocker is near garbage anyway heh. not accurate and the delay is horrendous.
