Im looking to Get some more power outta my car and maybe push some big numbers by spring, I know I need some bigger inj. and a AFM, also bigger turbo, Is this all I can do to make it get up and go?
Motor:
.40 Toyota pistons with Toyota rings
New Toyota main and rod bearings
New rod bushings
ARP main and rod bolts
New Toyota water pump
Newer belts
New timing belt and tension spring
New thermostat and radiator cap
New Toyota oil pump
All new seals and gaskets
New Pass. Motor mount
New power steering pump
New upper and lower radiator hoses
New oil overflow hose
4 puck clutch w/ new TOB assembly
Fidennza flywheel
Rebuilt master and slave cylinders for clutch
Mobil 1 10W30 synthetic
Relocated oil cooler
Relocated coolant overflow
Silicone vacuum lines
Head:
3 angle valve job
New Toyota valve seals and springs
2.0 Titan MHG w/ ARP bolts retourqed
NA cam shafts
New heater union and hose
EGR eliminated
A/C eliminated
NGK 1 range colder plugs and wires
Fuel:
255LPH Fuel pump
Aero Adjustable fuel pressure regulator w/gauge
FPD removal kit
Newer fuel filter
Nothing but high octane used at all times
Cleaned stock 440cc injectors
Turbo:
Upgraded ct26 done by Stevevangst never put a BC on it.
Larger front mount
Custom IC pipes. 2.5” steel lower and 2,5” aluminum upper w/ rolled ends and silicone couplers
Turbo XS RFL BOV
Apexi intake
Catch can
Electronics:
Black SAFC2
Autometer EGR,boost, and A/F gauges
Greddy TT
CD player w/ AM/FM ( cd doesn’t work though)
Pioneer speakers
Power antenna broke but in the up position
Silverstar headlights
Dual electric fans
Suspension:
Tokico Illumina 2’s all around w/ new bump stops
Eibach springs all around
Front Greddy STB
It does have a set of Mustang wheels on it now that don’t go with the car unless a little extra $$ is included in the price. Both the Mustang and saw blades have newer tires on them. Sawblades will be put on for sale if buyer doesn't want the Mustang wheels.
Brakes:
Newer stock front pads and rotors
New stock rear pads and rotors
New stock e brake shoes and assembly
Body:
Newer targa seals
Newer front and rear seals for targa
Newer rear hatch seal
Knock sensor rewire
Exhaust:
Titan Motorsport Downpipe 3”
Titan 3” test pipe
Blitz 3” Nur Spec catback
Motor:
New rod bushings
Newer belts
New Toyota oil pump
Fidennza flywheel
Head:
3 angle valve job
NA cam shafts
EGR eliminated
A/C eliminated
Fuel:
255LPH Fuel pump
FPD removal kit
Newer fuel filter
Turbo:
Larger front mount
Turbo XS RFL BOV
Apexi intake
Catch can
Electronics:
Black SAFC2
Greddy TT
Pioneer speakers
Dual electric fans
Suspension:
Front Greddy STB
Brakes:
Body:
Newer targa seals
Knock sensor rewire
Exhaust:
Titan 3” test pipe
