Need to make a name change on your Southwest boarding pass? Don’t let a typo or misspelling delay your travel—get expert help fast with just one click or call
+1 (866) 228-4206. Whether it’s a simple error or a legal name update, the Travel Changes Help Team is available 24/7 to guide you. One call is all it takes—
+1 (866) 228-4206!
Yes—if it’s a correction, not a full transfer. Southwest allows:
+1 (866) 228-4206 for real-time assistance.
+1 (866) 228-4206 to speed up the process.
+1 (866) 228-4206 will explain any costs upfront.
+1 (866) 228-4206 and fly worry-free.
+1 (866) 228-4206
Travel Changes Help )< one click!
Name corrections made simple at
+1 (866) 228-4206
Ensure your boarding pass is 100% accurate—fix it now!
Can You Change the Name on a Southwest Boarding Pass?
- Minor spelling fixes (example: “Jonh” ➝ “John”)
- Legal name changes (marriage/divorce with documents)
No transferring the ticket to someone else
How to Update Your Name on the Boarding Pass
The fastest way to update your name is to:- Call
+1 (866) 228-4206
- Or use Southwest's travel help chat
- Submit documentation if needed (e.g., ID, legal name change proof)
Get a corrected boarding pass issued fast!
What Should You Prepare Before Calling?
To correct your name on the boarding pass, you’ll need:- ️ Your confirmation or booking number
- A valid ID that matches the corrected name
- Any legal documentation (if applicable)
Are There Fees for a Boarding Pass Name Change?
Good news: Southwest charges no fee for name corrections. However, a fare difference may apply if your change affects travel plans. The expert at
Why Fix It Now?
TSA requires that the name on your boarding pass matches your ID exactly. If it doesn’t, you may be denied boarding. Don’t wait—call
