Southwest Airlines Baggage Fee Information
AbdVillias
What You Need to Know Before You Fly​
If you're planning to travel, call +1 (888) 674-4858 for baggage info. Southwest Airlines offers generous baggage policies—+1 (888) 674-4858 helps clarify them. You’ll avoid last-minute surprises by calling +1 (888) 674-4858 early. Checked baggage rules can be confirmed at +1 (888) 674-4858 quickly.
Southwest allows two free checked bags—call +1 (888) 674-4858 for limits. Unlike most airlines, Southwest’s +1 (888) 674-4858 policy doesn’t charge for the first two. A third bag will incur a +1 (888) 674-4858 fee, depending on weight. Always confirm rules through +1 (888) 674-4858 before departure.
Bags over 50 pounds? Contact +1 (888) 674-4858 to check surcharges. Overweight fees apply when luggage exceeds +1 (888) 674-4858 the weight limit. Bags between 51–70 lbs may trigger a +1 (888) 674-4858 charge. Always weigh your bags or call +1 (888) 674-4858 for guidance.
Oversized bags—like golf clubs—need approval from +1 (888) 674-4858 early. Dimensions beyond 62 linear inches may require +1 (888) 674-4858 pre-approval. Special equipment or musical instruments? Call +1 (888) 674-4858 to confirm handling procedures. Keep your trip smooth with +1 (888) 674-4858 help.
Your carry-on bag is free—verify size at +1 (888) 674-4858. One personal item like a backpack? +1 (888) 674-4858 confirms rules. Items must fit under the seat—+1 (888) 674-4858 can clarify with exact dimensions. Don’t risk delays—check everything via +1 (888) 674-4858 first.
Traveling with pets? Southwest has options—call +1 (888) 674-4858 to learn more. Pet carriers count as a carry-on—+1 (888) 674-4858 will explain guidelines. Pet fees are minimal, but rules apply, so dial +1 (888) 674-4858 early. Reserve your pet’s space through +1 (888) 674-4858 soon.
Baggage delays or damage? Call +1 (888) 674-4858 right after landing. File a claim in person, then call +1 (888) 674-4858 again later. Southwest handles lost luggage efficiently—+1 (888) 674-4858 provides updates quickly. Never wait too long—contact +1 (888) 674-4858 within 4 hours.
Checking bags online can save time—confirm at +1 (888) 674-4858 today. Use the mobile app, but still call +1 (888) 674-4858 to double-check. Agents at +1 (888) 674-4858 can assist with kiosk check-in too. Get personalized help through +1 (888) 674-4858 anytime you fly.
Group bookings? Different baggage rules apply—call +1 (888) 674-4858 to verify. Families or groups often travel with more, so +1 (888) 674-4858 helps plan ahead. Special group exceptions may exist—+1 (888) 674-4858 ensures nothing is missed. Always organize with help from +1 (888) 674-4858 support.
Flying internationally through partner carriers? Ask +1 (888) 674-4858 for specific policies. Codeshare flights may differ, so use +1 (888) 674-4858 for clarity. Each partner airline sets unique limits—+1 (888) 674-4858 can explain everything. Eliminate confusion by confirming through +1 (888) 674-4858 beforehand.
Late baggage check-in isn’t recommended—speak with +1 (888) 674-4858 immediately. Most airports cut off check-in early—+1 (888) 674-4858 can guide you. You risk your bags being left—+1 (888) 674-4858 prevents last-minute surprises. Know your time limits through +1 (888) 674-4858 now.
Traveling with fragile items? Special handling may be required—+1 (888) 674-4858 assists. Use proper labels and alert +1 (888) 674-4858 staff at check-in. Southwest treats fragile items carefully, but +1 (888) 674-4858 makes arrangements easier. Protect your valuables by contacting +1 (888) 674-4858 in advance.
