Today i was driving into town to lordco and i had my heat turned on to defrost my windows, when i stopped and turned the car off and took the key out the heater stayed running for at least 5-10 seconds after and the numbers displaying the temp flashed back and forth from one number to the other. What is causing this???
It just stated doing it today.
Last night I installed a new passenger door from an 89+, with my car being an 88 i had to cut all the wires from the door and splice them into the old connector. Could this have anything to do with it?
Also i just installed a Mishimoto electric fan and it is hooked up to the CIG fuse in the car. That cause it?
Any help is appreciated
EDIT: Found the problem. Fan was hooked up to the heater fuse and was messing everything up
