Some pics after getting lower
SC61 MK3
316
FL
I wasn't happy how the car was sitting on my eibachs and tokico setup. way too much gap in the rear. the 16 inch mkiv rims didnt help either. so i took the cutoff wheel and cut off 1 coil from the rear springs. now it rides the same and i think looks better. here are some pics
Shinobu
Mmmm... Juicy!
Columbus, GA
The rear looks a bit lower than the front but otherwise looks great. Really like what you did with the front end also. :)
SC61 MK3
316
FL
the driveway is at a slope. on an even surface the front is lower and rear a bit higher
dont mind the oil stains from all the messy projects in the driveway
Carls91Supra
So the front is untouched eibachs, looks low compared to mine? Looks nice though I gotta do the same thing to mine, but only to the stock rear springs:D
VanSupra
Van,B.C.
You should cut the fronts the same as the rears to keep the correct profile. Low in the rear is good if you're not planning on a high speed front end float show..
SC61 MK3
316
FL
the front was alot lower than the rear. i guess i need some better pics on a flat surface. yes the front eibachs springs are un touched.
