Iam getting smoke out the tailpipe, at idle is looks white at idle (not loosing any coolant) but when i rev it its blue, its burning a little oil, my question is how do i tell if its the motor or if its the stock twins going?
Check your compression it'll narrow it down some to possible valve seals or rings. I don't think it'd be turbo seals unless there completely blown but then youd know, you wouldn't be able to boost and or it would smoke during boost as well. Also does it smoke directly after start up, during deceleration or hard acceleration? More specifically when does it smoke and not smoke will help everyone in here as well to help.
I was told it has good compression, but ill check it. I havent had anyone follow me, so not sure if it smokes during boost, it smokes when i rev it up and when iam idleing after boosting. it smokes allittle on start up when its already warmed up.
