Smoke screen , oil shower!@#
88YotaTurbo
658
Wolcott, Ct.
So many of you know I dynoed my car last saturday and to mainly compare n/a to turbo cams. Right after the technician would release the throttle I would heavy heavy oil smoke coming from the manifold area in the engine bay and out the exhaust. What do you feel could be the issue? Here is some more info to help diagnose the problem. During the run I was pushing 15psi stock ct-26, 3" exhaust elbow back, Had the technician run the car to 6500rpm. Car would hit full boost at 3-3.5k and hold til done. After the dyno run I checked for external leaks (spots under car) and nothing. I also looked in the intake piping and found a nice oil slick I know was not there before, (since I cleaned all of that out previous to dyno).:1zhelp:
88YotaTurbo
658
Wolcott, Ct.
Well I was thinking around those same lines. It doesn't smoke unless i'm heavy into the boost for alittle bit of time. So, normal driving it is not an issue. Anyone else have ideas or support this idea?
