Silicone hoses
icepanthar22
lovin' the turbo spool...
Apr 22, 2005
67
Cary, NC
I am looking for silicone hoses for all of the associated radiator pipes, and I have not able to find them. I found silicone vacuum hoses on suprasport.com, but not radiator hoses.
Can anyone point me in the right direction?
clifftrail
128
Abq
Silicon will not make a good radiator hose. Although I'm sure that they make a big enough hose for it, they are not reinforced and won't handle the pressure the cooling system is going to put off. You wouldn't last long with the wrong type hose on the cooling system. There are some companies that make colored radiator hoses though that are the right material. GL.
supra90turbo
shaeff is FTMFW!
32
MA, 01440
1JZ hoses fit. The upper hose is identical, and the lower hose just needs to be trimmed slightly to fit. AFAIK they only made the 1JZ fitment, no 7M application was available.
