should i use this turbo
Rennat
5psi...? haha
Dec 6, 2005
2,844
Tracy, CA
i got a 3'' downpipe that will fit that, it even has a super tight 90 bend off the back so you can make a nice downpipe out of it to fit the supra.
just FYI
Red7m
123
Hollidaysburg PA
I have compare the dsm's turbo housing to my supra's and it should beable to bolt up the stock manifold with a little fab work. But there o2 housing would face up so that would need to be fabed as well. But shouldnt be much of a problem, also the dsm's have some awsome bolt-on turbo's that are much cheaper that our. And I dont see why they cant work with a little work. But there turbine housing are made for a little 2L and maynot beable to flow the air of a larger 3L.
MDCmotorsports
Indy 500
www.MDCmotorsports.com
I would think that turbo would be a "monster spooler" due to the small turbine and housing.
The compressor wheel is more than enough to get you in the 400hp range...
You'd need to fab up an adapter plate to mount it to the stock exhaust manifold, but as mentioned shouldn't be too bad.
The down pipe should be easy to make if you have any fab skills at all...
Run it! :)
