SHAKING cold starts....
Mosupra9
55
Tucson
everymorning when i want to start my NA/AUTO.....i have to crank it 2 or 3 times and when it starts..it shakes at very LOW RPMS and some times when i give it a LITTLE tap of gas it shuts off...but then i crank it again and it starts to warm up....i searched this but couldnt find an answer...any one can help..it would be appreciated....thanks
Fuzz420
Are U Here 2 take My Baby
Mine did this when my distributer need replacing. It would start up and barely be on, when i gave mine gas i could hear more cylinder firing but it wouldnt die, but the rpms would be sub 500rpm's.I replace my distributer and wires and she fires up and purs like a kitten
supramacist
1,501
The Grassy Knole
I definitley think that these cars need new plug wires and dist. caps more often than the average auto. I put all of the afore stated on less than 5k miles ago and are currently going to replace them for this build.
Big Wang Bandit
You Can't Quit Me Baby
Feb 21, 2006
7,551
San Ramon, CA - 925!
Pull codes.
Mine did this one morning. I got a code 11 or 12. I checked my resistance through my plug wires. Bingo. Plug one wasnt workin. Replaced it and voila! Runs good.
Jus10dun
Springhill,FL
I have the exact problem but i am not sure if this is the reason yaet because i am rebuilding right now.
But I found this sensor unpluged and the point on the harness was ruined by the fan.
<a href="http://photobucket.com" target="_blank"><img src="http://i33.photobucket.com/albums/d69/jus10dun/IM000473arrow.jpg" border="0" alt="Photobucket - Video and Image Hosting"></a>
So, it is a sensor or the coolant is not going to the throtle body.
