To describe better, I am attaching a drawing.. I am able to shake the passenger side front wheel hub whith the wheel removed. From inspection, it seems the the part where the lower A-arm connects to the hub assembly is shaking (is this the lower-ball joint?). What could be worn? the part 43330 in the drawing? or part 43211? If so, is aftermartket O'reilly parts be adequate? or should I look for toyota part? I guess rebuilding anything is out of the question?
Thanks for your help.
