shaft play, ct12a
JASONA70
nomnomnom
Oct 27, 2006
743
socal
i heart kind of a slight knocking noise, when i rev the engine the knocking gets louder. its a slight knocking sound. you can only hear it if you really listen to it. i recently found out that i had blown turbo seals, now i think i have really bad shaft play with the turbooz. :rant2: just wanted confirm on it.
jdub
Feb 10, 2006
10,730
Valley of the Sun
If you're sure it's your turbo...that means one (or both) of the wheels is hitting the housing. Need to get that fixed...unless you want metal pieces going into your motor :eek:
MDCmotorsports
Indy 500
www.MDCmotorsports.com
Ct12a's will either have aluminum going into your engine, or nice dust comming out your down pipe.
JASONA70
nomnomnom
Oct 27, 2006
743
socal
doesnt the intercooler block all that from going to the engine? i just need a confirm of what shaft play sounds like. i mean it sounds like knocking.the JZ never has rod knock! its because its the engine made by god himself!! anyways if anyone could confirm this
jdub
Feb 10, 2006
10,730
Valley of the Sun
Depends on how big the pieces are...you could be shaving aluminum off the inside of your compressor housing.
I wouldn't count on the IC to stop it.
JASONA70
nomnomnom
Oct 27, 2006
743
socal
what are the chances of shaft play on the ct12a? *the 1st generation ct12a* the motor has about 30-40k on the it and the turbos the same. i guess you could say i was boosting pretty hard with them, but does blown turbo seals effect the other parts of the turbo, such as the turbine and such.
time to post in the WTB section. *wtb: ct12a*
MDCmotorsports
Indy 500
Take off the compressor intake hoses and wiggle the shaft. If it moves side to side or front to back - YOU have shaft play. ;-)
The problem with the ct12A's turbine is its ceramic. If it does touch the turbine housing, chances are it chipped. Unlike a "rub" from a inconel turbine, the chip throws the balance out must faster.
ViR2
Supraniac
May 20, 2006
932
Lithuania
www.hpaddict.eu
Yes, IC stops some pieces, but smaller one's or even dust can pass through it ;) If you do have shaft play with ticking noise - change your turbo's as soon as possible, otherwise your engine is in danger. U might as well just go single ;)
Ric
Setting the standard
Feb 22, 2007
1,432
Central Florida
www.1jzgte.us
I had a big GT40 have a bad thrust bearing and rub the housing. It makes a nice loud harmonic screeching noise, not ticking. Think of nails on a chalkboard, VERY loud.
CT12A blades are a ceramic alloy, turbine and compressor side, not "steel". You'll shatter them like an egg and destroy your engine if the compressor side lets go.
JASONA70
nomnomnom
Oct 27, 2006
743
socal
i dont have enough money to go single =( i have like more than half saved up. maybe i should go with driftmotions ct26 upgrade for the 1j. and upgrade the ct26.
bigaaron
4,692
Pomona, CA
www.driftmotion.com
I can upgrade your ct26 and I just installed our manifold with Tim on his 1jz last night. We couldn't get it running becuase there was more to be done to complete the swap, but he liked the manifold a lot and exerything fit just fine. He had a different downpipe I had not seen before, but it did come out exactly where it should for the catback. I'll have the pics up tonight.
MDCmotorsports
Indy 500
Thats a death whine. It has very few hours to live.
Ct12A TURBINE blades are ceramic. The compressor wheels are aluminum.
JASONA70
nomnomnom
Oct 27, 2006
743
socal
i guess ill just have to pull the whole unit out and see if it has any shaft play. i hope so, or else it goign to be another big problem.
driftmotion let me know when the ct26 1jz is up ^^
JASONA70
nomnomnom
Oct 27, 2006
743
socal
well i took the compressor housing off, and it has a little shaft play. but well see when i take the whole thing off. oh any i have blown turbo seals for sure, OIL EVERYWHERE!!! ITS HORRIBLE JUST HORRIBLE
