Scrubbing front right only.
R1GG5
Huntsvegas
Just installed tokico illumina 2 shocks and b&G springs everything went well but I scrub on the front right only. It scrubs far worse when making a right turn. It seems odd to me because I figured it would scrub more when making a left turn and it leaned right. I have gone over everything with a fine tooth comb and I am at the point to where I am going to pull it out and do it again. Does anyone know what would cause me to scrub on one side only? Wheels are 18x8.5 front 18x9.5 rear +35mm offset, 245/40/18 front 275/35/18 rear, ST swaybars. Bushings seemed okay.... :1zhelp:
J
kabanimk3supra
kabanimk3supra
Apr 11, 2007
511
oklahoma
Maybe you have something slightly bent in your suspension, maybe the previous owner hit a curb and knocked something out of wack. Maybe you couldn't tell until you lowered it because the tire was further away when it was at stock height.
you can go to an alignment shop and have them try to align it, they will likely be able to find the culprit if it exists.
