Running Rough, really need help
Imagination6788
30
Atlanta, GA
So I've read through a ton of posts, but I can't find exactly what is going wrong with my car. For some reason my car when it starts will usually idle around 1100 rpm, occasionally it will try to idle at the correct 700, but does so really rough and ends up moving between 400-700 rpm. Btw, its a 86.5 w/ 238,000 miles. Also, when this problem started my brakes starting acting up (this may just be a coincidence). The brakes just seem to be loose, but will still lock up. When I hold the gas down in neutral and push the rpm from idle to under 2000 its fine, but once I get over 2000 it will suddenly drop 400-600 rpm and run really rough (like being in 4th at 15 mph). When driving I don't notice this until I sit on the gear (like using engine braking), then you can hear popping sounds and occasional it will jolt. I just recently passed GA emissions and they said everything looked fine on how it was running. My brother who had the Supra before me said it did this and he thinks the mechanic just replaced the egr valve. It averaging 22 mpg on the freeway and 17 in the city if I drive nice, 20-15 if I'm not. Can anyone help me out with this?
I posted this on supraforums, but a friend told me to post this on here.
Imagination6788
30
Atlanta, GA
So I finally figured out how to get the Super Monitor to spit out codes and it says 14 and 41 for the engine. But my check engine light has never come on.
plaaya69
87T Supra
Nov 18, 2006
947
10
Lake County, IL
14-- Ignition Signal
Diagnosis
No "IGF" signal to ECU "A" times in succession.
A = 6-8 (7M-GE)
A= 3 (7M-GTE)
Trouble Area
Igniter and ignition coil circuit
ECU
41--Throttle Position Sensor Signal
Diagnosis
Open or short circuit in throttle position sensor signal.
Trouble Area
Throttle position sensor circuit
ECU
Imagination6788
30
Atlanta, GA
I havn't checked it yet, buy I did unplug the throttle position sensor while the car was running and the idle increase and the engine ran better (no misfiring), but ran richer (or so it smelt that way)
plaaya69
87T Supra
Nov 18, 2006
947
10
Lake County, IL
Is that the orginal TPS sensor or has it been replaced? If it is orignal then it should have some yellow paint(with no markings/chips on it like someone used a screwdriver to remove the screws) on the two screws that hold the TPS sensor to the throttle body and if it has been replaced before it could be that it is not adjusted right or its not sitting in correctly.
Imagination6788
30
Atlanta, GA
Its the original. I tried to use the tsrm to test it, and the resistance was a little outside of the range. I'm going to replace the sensor and throttle body, and do a tune up.
robbo185
693
Chicago
if it was outside the range then just adjust it until if its inside the range. Then and only then you should replace it if you cant acheive that. Dont waste money if you dont have to
Clip
The Magnificent Seven
Oct 16, 2005
2,738
9
Virginia
yeah, if i remember right the TPS is pretty expensive, just try to adjust it first.
Imagination6788
30
Atlanta, GA
I found a used throttle body w/ tps for $43 shipped. Next time I am home I'm going to put it in the shop and get new valve cover gaskets, cap, rotor, spark plugs, wires, oil change, and the new throttle body w/ TPS. And probably bleed the brakes and replace pads (if needed), and what ever else is included in a tune up. I'm hoping this fixes my problem, I just bought a parking pass for $325. and I have to pay the deductible on the Maxima (hit and run). So it may be a little while until the Supra gets fixed.
CRE
7M-GE + MAFT Pro + T = :D
Oct 24, 2005
3,485
Denver, CO
You might try doing some of that yourself, those are among the most basic tasks and there are instructions readily available online (TSRM - Toyota Service and Repair Manual - it's been scanned is hosted on a couple sites).
Imagination6788
30
Atlanta, GA
I reset the the EFI and for a while I wasn't pulling codes, then I pulled a 41, then a 14, and now I'm pulling a 42. Does 42 have anything in common with the other 2, other than the ECU?
