running really rough
87turbo_swap
Meridian, ID
just got my car put back together and it ran fine for about a day and then started running really bad. all intercooler piping is hooked up, but as the title says, it runs really rough. i have installed a SAFC II and when the car is barely running, the SAFC will read out SAFC, like when you first start you car. then it will go blank and read SAFC again,and continues to do this. if you have one you should know what im talking about. i have changed the spark plugs and i am getting feul and spark.
any advice would be helpful
thanks
robbo185
693
Chicago
did you mess with the afc settings??
and if the ecu power/ground is messed up on sure that it will have an effect on the way your car runs due to the fact that the ecu keeps losing power or something...im sure someone can correct me if im wrong
