Hi all, I'm new to owning a supra, however I've been reading things on them for the last 2 years.
I bought '89 supra 7mgte manual, everything is fine with it except:
Cold start: when it's cold and I want to start it, it will crank for about 10 seconde before firering, which is kinda long, but the weird part is, as soon as it fire up. the rpm drop to 400.
that's the second issue: idle is 400 rpm COLD OR HOT
the third issue: if I drop the car in neutral (or press the clutch pedal) while the engine rev over 3,500 rpm (no load AND load, its the same) the engine stall but will restart and go fine if I put it back in gear while moving.
also, head gasket is fine
Thanks guys
Thanks guys
