Removing throttle body
radiod
1,342
Abbotsford, BC
There should be a couple brackets bolted to the side of your head above your exhaust manifold as well as a bolt bolting the thing down in the middle of the cylinder head valley between the cam covers. If you're wondering about the rod going between that linkage and the actual throttle, it's just a ball inside a socket and it should just pop off. Be nice, but you still have to apply a bit of pressure to get it to pop. The rest of the linkage you should just be able to push out of the way for the time being rather than playing with the adjusting nuts and whatnot.
alexscof
70
Pullman, Washington (WSU)
Perfect, that answers my question. Didn't want to break something if that rod wasn't supposed to just pop off.
Thanks.
---------- Post added at 05:36 PM ---------- Previous post was at 05:35 PM ----------
Thanks.
