rebuilding engine...
gmoney
supra is as stupid does!
Apr 22, 2005
97
CT
home1.myspace.com
this winter im pulling my tired 7MGTE out and rebuilding it. this is what i have picked out let me know what you think:
greddy timing belt
arp rod bolts
arp head studs
greddy mhg
main bearings
rod bearings
egr block plate
valve cover bolt kits
and having my head plained.
also removing the a/c, and redoing my whole drivetrain while its out with the 4.3 and the aluminum driveshaft.
gmoney
Apr 22, 2005
97
CT
home1.myspace.com
i was gonna do a gasket set but arent the stock pistons good up to 500hp? Th eje pistons are lile 750 ant thats about how much i want to spend.
Stretch
Tallest MK3 driver ever!!
Toronto, Ontario
ah, well atleast change the gaskets then, and if it's a tired motor make the water pump and oil pump also. They are probably near death and tired also.
eric
