Kind of a weird experince.
I have a set of KYB GR2's and a set of B&G Springs,18"x8 Zenetti Vega's mounted on Nitto NT555' 245/40zr18's on my car. Sometimes when I go over a bump,the rear almost seems to break loose for a split second,and i guess feel like its shifts to the left. Then it goes back to normal.
Recently I had to change the rear/passenger side strut because it blew a seal,(insert joke here),but that has been replaced.And it did the same "movement" when the strut was bad.
What might cause this? The tires are @ 40 psi,(max is 45):aigo:
