Radiator for power steering cooler?
CSquared
Atlanta, GA
I am in the process of a 2j swap on an 89 supra and was planning on using a second 7m oil cooler for the power steering fluid.
Then today I started wondering whether or not anyone has ever used the auto trans cooler in the radiator as a cooler for the power steering.
Would this be an efficient setup?
Has anyone done this? Stories? Thoughts?
It would seemingly make things a hell of a lot easier.
Thanks,
Chris
CSquared
Atlanta, GA
Yeah I actually found that out somewhere else. Still need a definite answer on the oil cooler question though. If they don't run external stock I'll just run my ps through the stock 7m cooler I already have.
CSquared
Atlanta, GA
tissimo;1308582 said:
They dont have an external oil cooler.
Awesome thanks.
That might be the first time I've saved money on this build... Historic.
EDIT: Your build thread is a godsend btw. Helps me answer all those "where the hell does this go" related questions.
OneJArpus
2,798
lol ^, i purchased a trans cooler from Advance auto for both my hydro fan & p/s cooler. Mounted where the condensor use to be.
I was going to put an external oil cooler too to find out i didnt need one but already purchased an RX7 cooler lol.
jmcboost
Missouri
Yeah, I used my stock 7M PS cooler and flipped it around so the inlet and outlet are closer to the PS pump. I cut a little of the PS cooler ends off and ran hoses to it that way. It saved me from having a bunch of extra hoses running across the engine bay. And no problems with it so far.
jdub
Feb 10, 2006
10,730
Valley of the Sun
Perhaps not, but I can say with 100% certainty a 2JZ-GTE would benefit from having a full flow thermostat controlled oil cooler ;)
pbasil1
Fully built 1JZ project
Jan 30, 2008
402
Huntsville,AL
I would add an oil cooler for the motor. I am on my 1jz, I pieced together one for about 450 using a 10x10 BM cooler and all stainless lines with earls fittings, block off adapter and remote filter housing.
tlo86
Ninja Editor 'Since 05'
Jul 24, 2005
3,914
Colorado
you can use the radiator trans cooler with an after market trans cooler to help warm it up
doesnt take a huge P/S cooler (i spent 15-25$) mounted it in front
the 2jz's have the coolant cooled oil filter setup nothing else hehe
CSquared
Atlanta, GA
Yeah that's exactly what I was thinking about doing originally. I was going to get a second cooler for the ps because I thought the 2j had to be externally cooled... But not I'll just use the stock bs.
On the rack... Which is the high pressure line and which is the low pressure line? (one port is closer to the firewall and one port is more towards the front end)
Also what kind of hose are you running for it? It seems like fuel hose is typically the most heavy duty.
EDIT: I will however add an oil cooler when I upgrade my fuel.
LordDigital
360
Chicago
Toyota have improved a lot of things on the MA70 ,one of the few that I've seen changed 4 times was the PS cooler. I saw a short pipe on my 87 supra ,a longer pipe on my 89 supra a single coooler radiator off my JDM clip and finally the V/H twin cooler design I took off of a 1992 USDM car (top of the picture):
Permanent&
Using the V/H cooler I've never had any PS issues - 2 drift events ,countless AutoX events etc :)
