r154 tranny
supraguy@aol
Well-Known Member
Dec 30, 2005
4,242
Atlanta
supratoyota18;1024760 said:
how can you tell if your tranny is a r154?
If you lift it, you'll blow out two discs. If you only blow out one, it's a W58.
:biglaugh:
The R154 has two black inspection/ access covers, one on each side of the bellhousing. The W58 has none. That's the most obvious visual difference.
tlo86
Ninja Editor 'Since 05'
Jul 24, 2005
3,914
Colorado
yeah the w58 looks really small thats for sure hehe and it is light, lighter than the r154 and about 1/2 the weight of a 2jz auto Lol
Fletch124
2jz swapped!
Jul 17, 2005
1,282
Reno, Nevada
supratoyota18;1025074 said:
i cant remember how the shift fork goes in does it go between option 1 or 2
#1 is where the throw out bearing is mounted. Your going to need all new washers and snap rings for the whole throw-out bearing assembly, I didnt buy new ones and my hub assembly fell apart when I was driving, had to pull the tranny and fix it a few weeks after installing a Spec Stage 3.
Nocheez
Probably posts too much
Apr 17, 2005
271
Charlotte, NC
It only goes in one way. You should put it in after you've tightened the pressure plate to the flywheel through the access panel.
