Quick radiator question
PROJECTTURBO
14
Wisconsin
Are the 7m-gte and the 1jzgte radiators interchangeable?
Curious if my 1jz fan shroud will work with a 7m-gte radiator.
What about the 2jzgte?
T.I.A.
staticpage
Banned: Scammer, liar, cheat and thief
Oct 3, 2007
310
Cincinnati
used my 7mge rad and shroud works fine, i even have pics some ware if anyone wants to disagree. I dont know if the 7mgte are the same as 7mge but its a temp setup i wont drive it with this rad
86_sports_1jz
slow 700hp build...
Aug 27, 2006
1,217
OK
T.I.A.
7m and 1j radiators should be interchangeable, i have a 7m radiator cooling my 1j. the fan shroud should be interchangeable also
no, not interchangeable
At least not directly.
I run a Koyo race radiator, and it's for the 1J. Has the temp sensor bumb and you have to fabricate brackets (and modify the aux. fan bracket) to make it fit a 7M shroud and aux. fans.
Supposedly the 7M radiator and shroud will fit a 1J/2J swap as long as you use a mechanical fan.
86_sports_1jz
slow 700hp build...
Aug 27, 2006
1,217
OK
yea, sorry forgot to add that if you have the hydrofan setup the radiators aren't directly interchangeable but if you have the clutch fan setup it is.
IfetheGreat
Heineken
Mar 11, 2008
22
Alief, TX
Well i'm about to order a koyo race radiator and wanted to know if the 1j and 7m units are the same. I am running electric fans btw.
Thanks
you'll have to plug the temp sensor hole somehow, modify the lower donut mounts (cut the rubber parts shorter so the radiator sits low enough), and figure out how to mount your fans.
