Quick Question in Turbo oil Drain
HardtopTE72
61
Tampa. FL
First let me say that i did try and search for a solid answer to this question.
Now my 1JZ came from what i think was a supra. So u had the mid rear sump pan. I switched to an Aristo?! front sump pan and it bolted on no problem. The only thing that im having a problem with is the turbo oil drain pipe. It can go 2 ways and neither way is perfect. I need to know if the front sump 1JZ has a different oil drain and if not what kind of hose did you guys rub to make it work. The reason i ask is the way i have it now the hose needs to make a weird loop and it doesnt seem very efficient.
Thanks alot.
Mike
tlo86
Ninja Editor 'Since 05'
Jul 24, 2005
3,914
Colorado
get the aristo fitting for the oil pan im sure a lot of guys have one laying around.. i do just not sure where it is!
marc3
canadian blood
Jul 19, 2006
229
quebec,canada
i got one. $30us + shipping. i would send it via usps.
i just bought one for a rear sump, cost me $60 canadian from toyota.
let me know if you want it.
