t04B a/r .96 on exhaust side and .60 compressor side REAL GARRETT/AIR RESEARCH turbo,
P trim turbine wheel
V trim compressor.
V-clamp setup 4" inlet on both intake and exhaust
Question:
Can someone please explain to me in laymans terms what the specs means?
What can it do in terms of spool and HP numbers ( an estimate is all I am looking for from the Pros) on a 1JZ engine ?
What advantage/disadvantage will one encounter if this was put on a 1jz.
Thanks in advance guys.
V trim compressor.
Question:
