Question on bored over block
b17what
14
indianapolis
I looked for a bit but not sure how to word the question in search. I bought a rebuilt block to replace my current externally cracked water jacket engine. Just found out its bored .040. I was planning on doing aftermarket rods and pistons because I was planning on 650+ on a built th400. What are my limits on a block bored out to the max?
Should I just dump this block for a untouched one? Would rather not because this ones is really nice besides my issue above.
GC89
1J-THIS
Jun 13, 2007
938
Spokane, WA
.040 over is the max I have seen. Has it been run since being bored or is it fresh?
If its fresh and they cylinders check round I would say get some .040 over pistons of choice and run it.
b17what
14
indianapolis
GC89;2053088 said:
.40 over is the max I have seen. Has it been run since being bored or is it fresh?
If its fresh and they cylinders check round I would say get some .40 over pistons of choice and run it.
I know it's max. That's why I'm worried. It's got stock stuff in it. I just don't want to blow through head gasket in the thin spaces between cylinders or warping the cylinders if I'm pushing very high boost. Basically I don't want to put $800 Pistons in it if it's just going to not work for what I want and then have to by new ones for a smaller bore...
GC89
1J-THIS
Jun 13, 2007
938
Spokane, WA
Plenty of people running big power on .040 over, that's not an issue. However if it was bored/built with factory cast pistons that's not the best situation as you normally run tighter clearances with forged pistons.
b17what
14
indianapolis
GC89;2053094 said:
Plenty of people running big power on .40 over, that's not an issue. However if it was bored/built with factory cast pistons that's not the best situation as you normally run tighter clearances with forged pistons.
I appreciate the info!
Jonnymkiii
High Altitude
Boulder, Co
It was my understanding that 1mm over (84mm) was the ~max bore size; I know you can easily find 1mm+ over bore forged pistons out there. I am pretty sure you can bore it out 1mm+ and be fine.
