Question about rear end.
1_slo_92
145
Hillsboro Ohio
Im new to supra's but I just fell into a 88 supra turbo. I was told that it has lsd but it's almost like a clutch and sometimes it engages and sometimes it doesn't. Anywho I need to know which rear end would be best? The mod list on the car is fairly decent and if needed I will post up but I got this car hoping to build a fairly fast weekend warrior. Any help would/will be appreciated.
suprarich
Guest
Nov 9, 2005
2,187
ohio
Hello and let me be the first to welcome you to the site, being a fellow statesman and all. Do all the searches about the LSD first, and read the FAQ section. Most anything you will ever want to know about the car can be found there.
87CandyBlueT
553
Kentucky (NKY)
Welcome to the site. Also if you look at the differential cover it should say either LSD or LSD oil only. Theirs a meet in Louisville, KY Sept.23, and 24th. How far are you guys from Cincinnati?
suprarich
Guest
Nov 9, 2005
2,187
ohio
I'm in Kent ( Home of Kent state university), you may want to check out OhioSupras.com for local meets. Not sure where Hillsboro is, sounds south and west of me.
1_slo_92
145
Hillsboro Ohio
Im a little less, or more of a hour away depending what part of cincy im going to. I would like to go to the meet but can't I will have to work. Im thinking about going to edgewater on a test and tune really soon to see what my 88 will do (assuming the trade goes through which it should) Anyone down for a little MKIII gathering?
