I have an 86.5 NA which used to have a rough idle when starting hot which I could not correct. I attributed the problem to heat soak and left well enough alone.
While installing a new P/S pump, I accidentally broke a port off the BVSV on the thermostat housing. So, I bought a used one off the net and installed it.
Amazingly, although I have no explanation, the rough idle issue described above dissappeared. However, I'm now having a worse problem. Instead of a rough idle at start when hot, it doesn't start at all unless I wait about five minutes after a failed start to try again. Again, only when hot. This hot start problem is intermittent.
Does anyone know if the BVSV can in any way be responsible for this type of behavior? Could it be possible that the replacement BVSC while looking like the correct one is not correct?
Appreciate any advice someome may have with this as I don't want to waste time looking at the BVSV if it cannot have anything to do with this.
Thanks
Thanks
