Question about OE headgasket
Sl1dewaysSupra
Destroyer of FWD's
Mar 14, 2006
690
Colorado
So I got a complete engine gasket set, everything I need for a complete rebuild. The HG is the "revised" OEM HG from what I have been told, looks alot beefier than stock for sure. Just wondering what the max boost I could run on my NA-T and still be safe. My goal is 10-12psi, not right off the bat of course. Will this HG stand up to the task?
bowsercake
828
Irvine, Ca
With Arp head bolts/studs and no detonation you will be fine at that boost level. Are you going to use a SAFC or maftpro or some other piggyback?
CRE
7M-GE + MAFT Pro + T = :D
Oct 24, 2005
3,485
Denver, CO
Yeah, he's planning on going with the MAFT Pro.... one of these days. heh
If you don't use it Sl1deways, I will. ;) I've got the feeling the wife's about to cut off all my Supra funding for some time.... :cry:
starscream5000
Senior VIP Member
Aug 23, 2006
6,359
Hot and Humid, KY
If 12 psi is all you think you'll ever want, then you should be fine with a composite HG with ARP hardware torqued to the correct specs per the sheets that come with them.
jdub
Feb 10, 2006
10,730
Valley of the Sun
Make very sure you check the head/block deck for flatness per the TSRM. If you do decide to go with a MHG, there is an RA spec for smoothness that also has to be met...this is not required for a composite gasket.
Heed what what Chris said about ARP torque specs. The sheet he mentioned is specific concerning lube...that will drive the final torque. Do not exceed the specified torque.
Sl1dewaysSupra
Destroyer of FWD's
Mar 14, 2006
690
Colorado
^ I just ordered ARP head bolts last night. I'm pretty sure 12 is about the max I wan't as the car will also be my daily driver. But from what I hear once you get a little boost you just keep wanting LOL. I am sure that a MHG is in my future, but for now I need to get the car done so I can get back in school.
bountykilla0118
In Pursuit of 500rwhp
Jul 16, 2005
1,088
Atlanta GA
ViR2 said:
it will hold for sure, but it also will fail after some time. I would go MHG way just to be safe ;)
All things fail with time. Just prep it good and use arp stuff. I am using toyota bolts tq at 75lbs and i have been boosting 14psi for 2 years now and no issues. However if I was to do it all over again i would bought the arp stuff.
Rajunz
Fast Coonass
Austin, Texas USA
starscream5000 said:
Just make sure the head and block are flat for the composite HG. You may want to considerd a copper spray for it also...
I agree, I would use Copper spray and also I would not torque it down more than 70 ft. lbs using ARP Molley Lube. You can over torque those things and deform them before you ever start it. If you are using stock head bolts, try to get some ARP Molley Lube. Alot of shops that build race engines have tons of those tubes lying around. The ARP Molley Lube will give you a different torque reading than using motor oil on the threads. Also, get a thread chase or thread tap and clean all of your head bolt threads out using WD40. This is real important in order to get accurate thread readings. Follow the torque sequence in the TSRM and do it in 3-4 rounds.
jdub
Feb 10, 2006
10,730
Valley of the Sun
Care to explain why? Or are you just pulling a number out of thin air?
If ARP hardware is used, the ARP torque specification should also be used. More than one HG job has had to be redone because ARP studs/bolts were not torqued properly...however, an over torque is worse than under torquing ARP hardware.
dugums
Better, Faster, Stronger
Apr 10, 2007
699
Chicago, IL
I'm really interested in hearing thoughts on this. My head is going back on tomorrow. I am using a composite gasket and would like to hear what the risk is with torquing all the way to ARP spec. I have both ARP studs and bolts, so I was planning on using the studs.
