Question about injectors
Supraboy89
357
Hampton GA
Waz up guys.I have a 89T I have all mods done to intake exc IC.I have 3inch exaust from turbo back. I also have warlboro in tank. I am running 15psi on stock turbo. dynoed at nopinationals at 243rwhp.If i use 550s on my setup will i be over 300rwhp.
oscolivar1
Supraism
Feb 8, 2006
1,000
Virginia beach
just adding 550 with a stock turbo (ne rebuild) then no....
it all about the tune.....
pick up safc and a wideband to tune saftley....
and im guessing your using a lex afm cuz your running 15 psi......
TobyCat
470
Vancouver BC
243 seems a little low for mods you've listed...especially at 15psi. You need a SAFC to tune that badboy. You might as well pickup an adjustable fuel pressure regulator with those 550s.
Mr.PFloyd
I am the Super Devil
Jun 22, 2005
3,964
Mississauga, Ontario
its not that low at all IMO. if he had a ddp then hed get much more ;)
honestabe
Happy as hell :D
Jan 15, 2006
3,713
Mount Vernon, WA, USA
I should probably add that you shouldn't buy Venom injectors. There are a ton of people having problems with them. They have proven to very inconsistant right out of the box. There is a huge discussion on supraforums if you want to look into it more.
Adam
Jeff Lange
Administrator
4,926
Sunnyvale, CA
jefflange.ca
CryoSlash said:
to add, injectors alone doesnt add horsepower, they allow you to run safely at high boost.
CryoSlash, can you please make your sig image smaller, it doesn't fit within the guidelines for signature image size. Thanks man.
Supraboy89
357
Hampton GA
I have a modded afm. I drilled out the adjustment screw hole and backed the screw out. Thats how i am running 15psi of boost. I do have a afpr set to 40psi . I also save a AFR guage. Accroding to it i am not running lean. But it is wired into the stock o2. Also how much rwhp do u guys think i should be running on my setup
Mr.PFloyd
Jun 22, 2005
3,964
heh damn jeff, this is just height tho right? cause my other sig owned this one in size haha.
-Thomas
starscream5000
Senior VIP Member
Aug 23, 2006
6,359
Hot and Humid, KY
Is you AFR gauge narrowband or wideband? If it's the little pillar pod shit with the cool lights, don't trust it completely ;).
If the downpipe doesn't have an integrated elbow on it I'd say your loosing some power, but I haven't checked to see what your mods are (if you've posted them yet in your profile ;) ). I'd say you should be close to 300 with what you've got so far... What's your torque?
I'm also asuming you have ic hardpipes correct?
Supraboy89
357
Hampton GA
I have custom hard pipes from turbo to TB. I dont have turbo elbow but i only loose about 2psi of boost at 6000rpm. I have a sunpro afr guage dont really know if it is wideband or narrow it was gave to me bran new by a friend. I dont know what my torque is but i drag race it at Atlanta motor speedway and it pulls really strong i ran a 2005 mustang gt and just barelly beat him by half car link.
