Thanks supraguy.. I had the rack already off.. so, I left the damper mount on, and just unscrewed the whole piece with damper braket from the rack piston.. worked just fine.. used two wrenges 7/8" and 1-1/4" wrenges to take the rack end off..
Per the TSRM, I need Dextron II ATF for power steering. This is red fluid, the current fluid is clear in color.. so, putting in "power steering fluid for all" from autozone is not advised? any issues with mixing fluids? or should I replace all the PS fuid in the car with new Dextron II ATF?
