Profec-E01 dispay help....
rakkasan
Currahee!!
Fort Campbell, KY
My profec-e01 displat went out (boost controller only, no emanage). I can tell it's still controling the boost, & I've looked the wiring over and nothing is grounding out, so I'm at a loss. Anyone have this problem before?
simpsons7s
Its pronounced Nu-clear..
Oct 9, 2005
253
Riverside, Ca.
Reset your sd card. also make sure it is away from any heat sources. Mine had display problems untill I moved it away from my vent because of the heat.
rakkasan
Currahee!!
Fort Campbell, KY
I checked the wires out as QWIK mentioned, they looked fine.
Where exactly is the SIM card? I looked but I couldn't find it. Also, what is the number for Greddy, they don't display a number on their website....
tissimo
Stock is boring :(
Melbourne, FL
Open it up. Check to see if the wires didn't pull out.. Its unlikely but why not? I had a afc that didn't work.. opened it up and the plug that the wires were on pulled partially out.
simpsons7s
Oct 9, 2005
253
Riverside, Ca.
The sd card is located on the side of the display, it is about an inch long and blue. You have to pull it out and put it back in while it is on and that resets it.
rakkasan
Currahee!!
Fort Campbell, KY
Cool, thanks. Checked it, but no luck. I think I'll have to pull it apart to get to figure it out, but I'm going to call Greddy first...
bowsercake
828
Irvine, Ca
GREDDY PERFORMANCE PRODUCTS
9 Vanderbilt, Irvine CA 92618
Tel: (949) 588-8300 FAX (949) 588-6318
I know a few of the guys working there. Hopefully they can help you out.
