Hey, I have a big problem. When I step on the gas to spool the turbo, the car moves a little and then hits fuel cut. The boost controller is set at stock, and the boost gauge only reads a 4 psi or so before fuel cut hits. It seems like the car is running really rich, because the air/fuel ratio gauge stays at green. The car is hitting fuel cut and the engine check light comes on everytime the turbo kicks. I know fuel cut is at 11.8 psi or so, but it does this at 3-4 psi. Also the car blogs and hesitates when turbo begins to spool.
I've checked all the vacuum lines, intake pipes, exhaust pipes, eletrical wires to the ecu, change the afm, and it still does it. I think it might have something to do with the TPS not working properly. Anyone have any idea on what might cause this. Thanks.
