Problems and Need Help ABS, O/D lights flashing
zdale
4
houston
Okay here is the deal. Swapped a 88 motor, Harness, ECT into a 87 Body, both cars turbo abs. Everthing went good Except I now have a flashing o/d light and Solid on ABS light. Pulled codes form tranny and Abs both say I have a Bad speed Sensor. Swapped sensors from another Tranny I had cleared codes. Both Codes come back.
Tranny Shifts fine, Cruise control works, Car upshifts and downshifts fine, O/D works as it should. Tems lights are working so I guess the TEMS is also working.
Only thing not working is the abs. Continuity checks out and my Ohm readings are in spec for both sensors.
Out of Ideas any one help me I would appreciate it.
Thanks
Zdale
